Previous in Forum: Measuring Instrument in Bus Tie - MV/LV Switchgear   Next in Forum: Synch Selector Switch - Auto Transfer Scheme
Test Terminal Block/Test Switches in MV Switchgear
04/07/2026 5:19 AM
The test terminal blocks or the test switches to be fitted inside the LV cubicle of MV switchgear or on the door of the MV switchgear. Which is better and why?
Re: Test Terminal Block / Test switches in MV Switchgear
04/08/2026 12:39 AM
The preference would be to mount the test switches and terminals on the door external to the inside of the MV cabinet.
This way the cabinet door provides a barrier to the MV internal to the cabinet and reduces arc flash consequences should something internal fail during the access and testing. It also prevents inadvertent contact with live metal contacts within the cabinet.
Remember one flash and you're ash!
Hare today, goon tomorrow!
Re: Test Terminal Block/Test Switches in MV Switchgear
05/03/2026 11:46 PM
On the door of the LV cubicle would be a typical location for MV switchgear in the past.
On the door of the MV cubicle would require additional engineering evaluation of the door strength under various fault conditions, where the door strength would be affected by equipment cutouts and/or flammable components.
