Previous in Forum: Test Terminal Block/Test Switches in MV Switchgear   Next in Forum: Load Sharing Communication Method
Synch Selector Switch - Auto Transfer Scheme
04/14/2026 4:46 AM
For the LV switchgear ATS (Auto Transfer Scheme), have you used a synch selector switch?
I am familiar with using a trip selector switch (TSS), where the TSS trips the selected breaker after momentary parallel operation.
How does the synch selector switch work in this scheme?
Are both the synch selector switch and the trip selector switch used together, or is only one of them required?
Re: Synch Selector Switch - Auto Transfer Scheme
04/15/2026 12:29 AM
I suspect that the designer of the equipment picked a name that appeared to describe its functionality. As to what each one actually does, to hazard a guess as opposed to reading the manual or even casually mentioning the make and model of the equipment, would seem to be useless.
