It's to give clearance for the valves to open at top-dead-centre between the blow stroke and the suck stroke, while maintaining a high compression ratio.
Innuendo is not Italian for a suppository.
I can tell you that if that clearance is not there, the engine will make a horrible noise...but only briefly! I learned early to place a bit of modeling clay on the top of my pistons and roll the engine over by hand to check the clearance before final assembly. A 0.025" clearance (without the head gasket) is absolute minimum.
Aequam memento rebus in arduis servare mentem.
To accomodate the valve; problems that arise from bad timing amd assembly have, at least, a degree of freedom from smashing the piston against the valves.
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
