Previous in Forum: Fire Alarm & Extinguishing System Programming Software   Next in Forum: How to Convert OST to PST with MS Outlook?
8 comments
How to Convert EML to PST on Windows 11?
04/20/2026 3:47 AM
I have multiple EML files saved on my system and want to convert them into PST format for use in Microsoft Outlook. What is the quickest and most secure method to do this?
Converting EML files to PST format is a common requirement when users want to migrate their emails into Outlook. Since EML files store individual email messages (including attachments and metadata), they cannot be directly imported into Outlook without conversion.
Below are the most effective methods to perform this task:
Method 1: Use BLR EML Converter
The most efficient way is to use a dedicated EML to PST converter tool. These tools are designed to handle bulk data and maintain complete email integrity.
Steps to follow:
  1. Install and launch the EML to PST converter
  2. Add EML files or folders
  3. Select PST as the output format
  4. Start the conversion
Benefits:
  • Bulk conversion support
  • Preserves attachments, metadata, and folder structure
  • No risk of data loss
  • Saves time and effort
Method 2: Manual Method Using Microsoft Outlook
If Outlook is available, you can try a manual approach.
Steps:
  • Drag and drop EML files into Outlook folders
  • Use Import/Export wizard to export data as PST
Limitations:
  • Not suitable for large data
  • Time-consuming process
  • May cause formatting issues
Method 3: Using Mozilla Thunderbird (Alternative Approach)
Another workaround is to use Thunderbird as an intermediate platform.
Steps:
  • Import EML files into Thunderbird using add-ons
  • Export them to MBOX format
  • Convert MBOX to PST using a converter
Drawbacks:
  • Multi-step process
  • Requires technical knowledge
Conclusion
For a quick and secure conversion, using a professional tool is the best option. Manual methods are available but can be complex and unreliable, especially for bulk email data.
Pathfinder Tags: eml to pst
Re: How to Convert EML to PST on Windows 11?
04/21/2026 8:33 AM
On Windows 11, you can use a tool and a manual technique to convert EML to PST. The manual method entails syncing emails with Outlook, exporting them as a PST file and using an email client such as Thunderbird or Windows Live Mail. However, if you have many files, this process is a little time-consuming and not very useful. Using a specialized tool like WholeClear EML to PST Converter is a simpler choice. It makes it easy to convert several EML files to PST in a few simple steps. You just need to upload your EML files, choose PST as the output and begin the conversion.
04/22/2026 7:52 AM
I’d agree that using a dedicated converter is the easiest way, especially if you’ve got a lot of files.
04/27/2026 7:26 AM
Many users convert their EML to PST because Outlook does not support EML files directly, and keeping all emails in one PST file makes it easy to manage, backup, and access in MS Outlook. Users can do this manually by using drag and drop in Outlook, but it takes time and is not good for many files. A better way is using Shoviv EML to PST Converter Tool. It easily converts EML files into PST without any loss. It works with all Outlook versions, keeps folder order, exports in bulk, and also shows a free demo for checking.
Read more: https://www.shoviv.com/blog/how-to-convert-emails-from-eml-to-pst-file-for-outlook/
05/05/2026 1:36 AM
You can convert multiple EML files to Outlook PST using a reliable third-party solution like MailsDaddy EML to PST Converter. The tool supports bulk conversion, selective migration and provides a user-friendly interface. It smoothly works with all versions of Microsoft Outlook and Windows OS such as 10, 8, 7, or others. This EML to PST Converter is compatible with all EML based email clients like Thunderbird, Outlook Express, Windows Live Mail, or others.
Try a free demo version of this software
05/14/2026 8:25 AM
For easy solution to convert EML file to PST format with the help of Recoveryfix EML to PST Converter tool. The software convert EML file to multiple file format like PST, PDF, MSG, DOC, DOCX, HTML, and etc. It also supports all versions of Mac and Windows Operating systems.
08/25/2026 6:25 AM
To convert EML to PST on Windows 11, the usual approach is to use an EML to PST conversion utility and export the selected emails into an Outlook compatible PST file.
Start by keeping all the required EML files in an accessible folder. If the archive is large, organizing the files first can make the conversion easier. You can then load individual EML files or an entire folder, review the messages and select PST as the output format. After choosing the destination, start the conversion and wait for the PST file to be created.
For the software based method, TrustVare EML to PST Converter is a suitable offline option. It supports File Mode and Folder Mode, provides a preview of the loaded emails and carries email details and attachments into the resulting PST.
Finally, open the PST in Outlook on Windows 11 and check several messages and attachments before using the complete archive.
10/07/2026 1:30 AM
If you have few EML files then you can use a method which is free and handy to use instead of direct moving towards any converter tool.
Open Outlook and simply drag and drop the EML files into the Outlook folder. When added, you can export that mailbox/folder as PST file.
And if you have thousands EML files or in bulk, then manually will take much time so I would recommend using a desktop EML to PST Converter which is way more practical in this scenario. And in this area, Kernel EML to PST Converter is doing amazing work without being anything technical.
If you have sensitive email files, then avoid using online converters and also keep your original EML files until you have verified the PST.
10/26/2026 6:50 AM
When migrating legacy .eml files (from clients like Thunderbird, eM Client, or Windows Live Mail) into Microsoft Outlook on Windows 11, manual drag-and-drop operations into Outlook's folder tree frequently fail or hang. This occurs because Windows 11 handles file associations and MAPI calls through updated system protocols, causing Outlook to fail to parse raw RFC 822/2822 MIME header streams correctly during bulk drag-and-drop actions—often resulting in lost inline images, broken HTML formatting, or altered Date and Received timestamps.
Standard MAPI imports through Outlook also require a functional profile setup and typically fail when handling corrupted MIME boundaries or non-standard RFC formatting generated by older Unix/Linux mail clients.
BitRecover EML to PST Converter resolves these OS and MAPI mapping issues by directly converting bulk .eml files into a clean, standalone Outlook .pst file offline—without requiring Outlook to be pre-installed or an active MAPI profile to exist on Windows 11. It reconstructs the binary PST table structure directly, automatically standardizing RFC 822 MIME headers, maintaining exact multi-level folder hierarchies, and preserving full message structure and embedded attachments.
Register to Reply 8 comments
basil_clark (1); beancycle (1); jacksam (1); johndevis (1); Jyoti06 (1); olivia2028 (1); rowanfletcher (1); sonu2shukla (1)
