Previous in Forum: Ammeter Location for Star-Delta Starter Circuit   Next in Forum: Arc Flash and IP Rating
Undervoltage Relay for Low Voltage Motors
05/07/2026 6:12 AM
Do you provide dedicated undervoltage protection for low voltage motors below 100 kW? My understanding is that, in this power range, undervoltage is typically addressed by the overload relay, since a drop in voltage leads to an increase in current. In such cases: Should undervoltage protection be provided at the MCC incomer (fed from HV/LV transformer)? (Or) Is it acceptable to leave it as is, as the upstream (high-voltage side) breaker will trip on undervoltage?
Pathfinder Tags: UV relay
Re: Undervoltage Relay for Low Voltage Motors
05/07/2026 8:24 AM
Absolutely. I have them on all motorized appliances. Refrigerators, A/C, freezers and washing machines.
Any guesses as to why I have done this?
You most certainly have a more reliable grid than I. You must determine the cost of the unit, the replacement cost including the labor of device(s) to be protected.
05/07/2026 11:36 PM
The only undervoltage relays I have ever seen applied on a motor circuit is a specialized relay designed to hold the motor contactor in, engaged, during an undervoltage event. These are typically applied on large motors, 500kW and up. These contactors have dc coils, so will not drop out until 20% voltage rather than the typical 60% dropout of ac contactors. The primary control circuit voltage is typically ac.
After a certain length of time the contactor will release.
The primary reason for these time delay undervoltage release relays is to avoid the situation where a large motor disconnects from the supply, and then reconnects before it has stopped turning. Out of step, or large magnetizing current can stress a power system, leading to a cascading power system failure. If not a momentary outage, the motor is disconnected and must be manually restarted.
Good Answers: 27
05/08/2026 8:08 AM
Since electrical appliances now are typically rated to operate with-in a +/- voltage variation..
The decision to provide under voltage protection in my view would be dependent upon the importance or criticality of the connected electrical load and its application.. applications like for health sustenance and life support equipment are good examples.
Which would also be after giving due consideration on the reliability and voltage stability as supplied into the area or location..
vsar
Register to Reply 3 comments
JWthetech (1); rwilliams (1); vsar (1)
