Previous in Forum: Yamaha Organ   Next in Forum: Statimeter M5537 for ISO pumps
19 comments
Stuck PVC Valve
05/07/2026 7:06 AM
I am sure I am not the only one who has this problem:
A shut of valve for the sink(S) that has not been opened since it was installed is now stuck in the open position. It was free when installed, so what has happened ,and does anyone know any tricks to free it up instead of cutting it out and replacing it? I am reluctant to apply too much pressure (channel locks, etc.) to prevent breaking the pipe.
Thanks in advance for all help on this matter.
Pathfinder Tags: pcv plastic valve stuck
Re: Stuck PVC Valve
05/07/2026 10:26 AM
Can you shut off the water supply to the house without a bunch of trouble?
If you are able to, shut er down and open the tap. This will relieve the pressure on both sides of the valve, this may be enough to allow operation of the valve.
Are these 1/4 turn valves? If not, it might be wise to switch them out anyway. Probably not worth the hassle, never mind.
Re: Stuck PVC Valve
05/07/2026 1:40 PM
tried that..no joy. Even broke a handle off of one trying to rock it back and forth to loosen it. This happens even on brass ball valves. Must be silt build up turning into hard cement over time. Even though I have a.5 micron filter something must be getting through.
I will l change them out ,but I will find out why as I tear down the old ones.
Re: Stuck PVC Valve
05/07/2026 2:03 PM
Wow, enough buildup to jam a ball valve. Do you also have the common symptoms of hard water?
When I hear PVC (or CPVC) piping I presume the valves are glue in? If yes, when you cut them out there will likely be a shortness issue with pipe length.
Well, if the valves are busted they have to be changed, that’s the end of the line. Best of luck to ya.
Re: Stuck PVC Valve
05/08/2026 3:08 AM
Thanks HiTekRedNek, when you find out, can you let us know what caused the jam?
Re: Stuck PVC Valve
05/07/2026 3:06 PM
You should also consider not replacing the stuck OPEN valve, but just adding a second shutoff valve.
Re: Stuck PVC Valve
05/07/2026 10:37 PM
If you end up cutting the pipe to remove it, install unions on each side of the new valve. At least it will be easier to remove the next time you have to replace it.
Re: Stuck PVC Valve
05/12/2026 7:08 PM
Well, if you don’t mind this look in an under sink valve, a PVC valve/union combination is available.
I dunno… if there is a valve fail you would have to acquire the same brand, and the way things are today, who knows if the selected manufacturer will be around?
Might be best to glue on a pipe thread adapter, then thread on a common chromed under sink valve.
Re: Stuck PVC Valve
05/07/2026 10:52 PM
I have seen many that would not turn by hand. The rubber O-ring binds to the metal shaft. Get some WD-40 and spray it then get some pliers and turn it off.
Re: Stuck PVC Valve
05/08/2026 4:07 AM
Let me say that I have had this same problem and swapped the valves out for Stainless steel ball valves which are rebuildable.
Just drain the system, cut the old PVC out and install a threaded in ball valve using an adapter to glue to the PVC pipe and if no movement of the pipe is a problem then use a ball union.
The problem with the valves I found on dissection was that the PVC had shrunk and there was a plastic white powder filling the bearing space and locking the shaft solid.
I have changed out all the PVC valves for rebuildable SS valves.
Hare today, goon tomorrow!
Re: Stuck PVC Valve
05/08/2026 8:59 AM
As you have a 0.5 micron filter I am presuming you are using Groundwater and not normal utility delivered water ? or are you filtering local utility water ?
It could be the local water hardness (what is your PH Value ?)
The best way is to warm the bottom of the Vavle to around 80°C, this will not damage the plastic but will allow it to expand quicker than the internal parts and should allow any limescale / sand deposits to crack and disperse when the water flows again.
Do not use the water while heating as this will cool the valve.
An alternative method (depending on distance to the taps) is remove the tap, siphon off the water in the pipe (assuming you can stop the flow elsewhere and then pour a mixture of 200g Baking Powder, 200g course salt, 200ml white vinegar and 200ml hot water down the pipe, leave to work for 15-20 mins then see if the tap moves..
Re: Stuck PVC Valve
05/08/2026 10:10 AM
I am thinking about MEK ,the pvc cleaner poured into the valve, with the input side blocked below the valve with plastic wrap packed in tight.
It will either fix or melt the whole thing nothing to lose at this point, going to swap them out anyway.
Re: Stuck PVC Valve
05/09/2026 11:58 AM
Maybe something helpful here
Note: A petroleum based product like WD-40 is not recommended.
Re: Stuck PVC Valve
10/10/2026 11:15 PM
I had a pvc sprayer handle that had locked itself in place, pvc on pvc. I was finally able to apply what seemed a dangerous amount of torque to the handle, and it released. I had filled the interface top and bottom with water, had to keep adding water on top, for 3 weeks. Even with that, it took significant force to unstick the interface.
My father always told me that water is the universal solvent, citing rocks in streams, but who has that kind of patience? :)
Re: Stuck PVC Valve
05/26/2026 7:52 AM
From plastics manufacture, the valve components would have a very slight taper on both parts, a little like a morse taper.
There might be benefit to try to "lift" the spindle relative to the rest of the fitting to disengage the tapered parts.
Often when trying to turn a tap, we place extra effort onto the spindle part and potentially engage it even more tightly into the other part.
Could be totally wrong, just an idea.
Re: Stuck PVC Valve
06/03/2026 5:11 PM
I haven't tried this yet but I take note that PVC expands with heat more than you would think, so I would try heating the valve in a series of heat and cold cycles to see if it would free up....I would wrap the valve in a wet cloth and hit it with a heat gun...I usually internally coat any PVC valves with pure silicone spray or grease prior to installation and work it back and forth till it feels loose...also periodically open and close the valve as a maintenance ritual...
Re: Stuck PVC Valve
06/18/2026 11:27 PM
I had the same problem with a brass undersink valve last week when I was trying to repair my dishwasher.
Rather than make a trip to the hardware store to buy another valve, I just turned the water off for the house.
Also last week, I was working on a toilet. The brass valve would turn, but it leaked. I replaced it with another valve (1/2" compression fitting) and I wrapped the compression sleeve with a couple of wraps of Teflon tape when I installed the new valve. It leaks. The pipe is too short to cut anymore off and replace the compresion sleeve. I did what any good engineer would do, I put a tray under it to catch the water.
Re: Stuck PVC Valve
09/10/2026 3:56 PM
Is there scope to warm it up without boiling the fluid inside it, preferably without using a flame?
Re: Stuck PVC Valve
10/11/2026 12:26 PM
I was about to suggest warming as well. Not Hot but just add some heat and expand the material a bit to crack the mineral deposits.
Re: Stuck PVC Valve
10/31/2026 1:34 PM
Stolen directly from the internet:
  • Shut off the water: Locate and turn off the main water shutoff before the stuck valve or have your local water company ready to shut it off at the meter if necessary.
  • Apply lubricant: Spray 100% NSF-61-rated silicone grease or silicone spray directly into the handle joint and seals. Avoid petroleum-based products like WD-40, which can degrade and crack PVC.
  • Wait: Allow the lubricant to penetrate for 15 to 20 minutes.
  • Apply gentle leverage: Use a strap wrench or wrap a rag around the handle/body and use channel-lock pliers with steady, controlled pressure—moving back and forth rather than forcing it in one direction. Avoid brute force, as PVC is brittle and easy to snap.
Cycle the valve: Once it starts to move, turn it back and forth multiple times until it operates smoothly.
CARPE CRUSTULORUM!
Register to Reply 19 comments
Deefburger (1); Doorman (3); evanmjones (1); HiTekRedNek (2); Just an Engineer (1); not so smart (1); PWSlack (1); redfred (1); Rixter (1); rwilliams (1); SolarEagle (1); StandardsGuy (1); Stef (1); steve45 (2); The Wizard (1)
