Previous in Forum: Online Leak Sealing   Next in Forum: 7 Line Facial Tissue Folding Machine
A Simple Tolerance Change That Can Significantly Reduce Manufacturing Cost
05/11/2026 5:28 AM
In many projects, one of the biggest cost drivers is unnecessarily tight tolerances.
For example, changing a machining tolerance from ±0.005 mm to ±0.02 mm can often reduce cycle time and cost substantially, while still meeting all functional requirements.
Other practical DFM strategies that usually help:
  • Use standard materials and stock sizes
  • Avoid unnecessary cosmetic surface finishes
  • Reduce deep cavities and very thin walls
  • Select the most appropriate manufacturing process
What design changes have helped you reduce manufacturing cost the most?
Pathfinder Tags: CNCMachining
Re: A Simple Tolerance Change That Can Significantly Reduce Manufacturing Cost
05/11/2026 3:31 PM
It reminds me, long, long ago, I was working as a student intern in a drafting shop. I labeled a quarter-inch hole 0.25000". One of the engineers there pointed out to me that this implied precision to the machinist in the shop, and if he took it literally, it would be expensive to make the part.
Live and learn...
05/26/2026 7:38 AM
We repeatedly determined our process capability and designed mating parts so that tolerances would be achievable and so that fit was always possible.
We developed a means to fit our parts into rectangular receiving holes in material of varied thickness and hole tolerance by simply putting a taper on the compressed clip rather than try to get exact thickness fit. No rattle, ever. Auto industry worldwide was using this when GFC happened and we closed.
DFMA principles to reduce component count by combining items that could be common material (injection moulding).
Interchangeable tools in shop all same "thickness" so that machine clamping never had to be adjusted. Saved time on EVERY tool changeover. We ran 25 machines with typically 10 changes per day.
"Crush ribs" on mating parts so that only small material volumes were needed to be deformed to achieve fit.
Corner radius ALARP to eliminate/reduce stress focus on inside corners of parts. Easier to machine.
Lots of other things associated to JIT, SMED, KANBAN etc.
Gee I miss those times.
07/26/2026 12:40 AM
Tolerance analysis. Something as simple as a one-dimensional "stack", using either RSS or worst case estimates of variation based on the tolerances provided, has often revealed assembly problems before parts even exist.
This of course REQUIRES that the tolerances are actually based on actual variation.
Greater cost or complexity warrants 3-D analysis (there's a bunch of software apps out there) but an experienced analysist is an important part of the picture.
Using precision components (because that's what's in stock) but attributing to them broad tolerances will ruin the analysis. Same for calling out (and analyzing with) tight tolerances you are not achieving in component variation.
Register to Reply 3 comments
Just an Engineer (1); Mfmatusky (1); Rixter (1)
