Previous in Forum: Plate Heat Exchanger Gasket Failure Issues & Best Replacement Solutions in India?   Next in Forum: A Simple Tolerance Change That Can Significantly Reduce Manufacturing Cost
Online Leak Sealing
04/30/2026 5:17 AM
I have been reviewing various articles and technical resources on online leak sealing procedures and techniques. From what I understand, there appears to be significant potential for industries to save substantial financial resources that are typically lost due to leaks in piping systems, vessels, and equipment.
Online leak sealing (also known as live leak repair or in-service leak repair) allows repairs to be carried out without shutting down operations, thereby preventing production losses, reducing downtime, and minimizing environmental and safety risks. Given the high costs associated with unplanned shutdowns and leaks, this technology represents an important area that could benefit from better documentation and structured data representation.
Pathfinder Tags: leak sealing
Re: Online Leak Sealing
04/30/2026 5:18 AM
I have found some relevant content here [redacted by Mods] , where thay mentioned about the BIS standard for Online Leak Sealing.
07/29/2026 6:18 AM
Sealing reliability is critical for high-pressure fluid transmission. Material compatibility with corrosive media is essential to avoid unexpected leakage.
Lonsuctech LLC High pressure hoses, plug valves & piping components https://lonsuc.com
09/10/2026 4:23 PM
The traditional one for leaking steam boilers was to introduce a slurry into the boiler before sealing it and steaming it. The slurry consisted of chopped straw, chopped oats, and pig manure.
09/30/2026 1:37 PM
The biggest benefit is probably avoiding an unnecessary shutdown. If the leak can be safely sealed while the system stays online, you can save a lot of downtime and production loss. The tricky part is making sure the repair method is appropriate for the pressure, temperature, and fluid involved.
MalcAndCheese
Register to Reply 4 comments
bee song (1); MalcAndCheese (1); PWSlack (1); somen1981 (1)
