Previous in Forum: How Do You Evaluate the Performance of Stainless Steel Pipes Over Time   Next in Forum: Are Aluminum Sheets Recommended for Aerospace Industry Wall and Panel Applications?
9 comments
Best Method to Convert OST to EML?
05/22/2026 4:47 AM
Method 1. Using Microsoft Outlook (Manual Method)
The manual method of converting OST to EML using Microsoft Outlook involves accessing mailbox data directly through an active Outlook profile linked to the OST file. Since OST files are synchronized with an email account, Outlook allows users to view and manage stored emails, making it possible to manually extract and convert them.
  • Install and open Outlook
  • Select the emails or folders
  • You want to export
  • Drag the emails to your desktop
  • They will save as.MSG file
  • Convert.MSG to .EML
  • Use the MSG to EML converter tool
  • And Drag into Thunderbird
  • Save as EML
Method 2. When the OST file is offline
When the OST file becomes offline or inaccessible within Microsoft Outlook, it means the file is no longer actively synchronized with its original email server or Outlook profile. This situation commonly occurs due to account removal, server issues, or changes in system configuration.
In such cases, direct access to the mailbox data through Outlook is not possible, making manual export methods ineffective. Therefore, specialized approaches such as using the OST Converter Tool are required to retrieve and convert the data stored in the offline OST files.
Re: Best Method to Convert OST to EML?
05/22/2026 8:23 AM
Convert OST to EML easily with Recoveryfix OST to PST Converter, a reliable solution for exporting Outlook OST files into EML format without data loss. This OST to PST Converter tool preserves email properties, attachments, folder structure, and metadata during conversion. It supports bulk conversion and works with damaged or inaccessible OST files as well. It offers a simple interface that helps users convert OST emails to EML format quickly, making email migration and backup management easier and more efficient for all users.
07/27/2026 8:52 AM
If you need to convert an OST file to EML, the easiest method is to use a dedicated converter. Manual methods are limited and typically require Outlook with access to the original account.
The SysTools OST Converter lets you export OST emails to EML while preserving attachments, email formatting, metadata, and folder hierarchy. It supports healthy, orphaned, and inaccessible OST files, as well as bulk conversion for large mailboxes.
08/07/2026 6:11 AM
The best method to convert an OST file to EML is to use a reliable converter, especially when the mailbox is large or the OST file is no longer accessible in Outlook.
I had to transfer an Outlook mailbox to Thunderbird and realized that the manual procedure was not enough for a full mailbox transfer. Having tried many ways, I used GainTools OST to EML Converter. It helped me to open the OST file, preview the mailbox and choose only the required folders for export without any changes to the original mailbox hierarchy.
When you have years of e-mail in your OST file, or when Outlook no longer works with it, this approach seems much more convenient.
09/12/2026 12:46 AM
The tricky part with OST to EML is that the manual Outlook method is only really convenient when the OST is still connected to the original account. In the thread, the proposed method also adds an MSG step in between, so for a full mailbox it becomes a bit of a long process.
For an offline or orphaned OST, I would go with a direct converter instead. BitRecover OST Converter is one I would consider because it can open the OST directly and export the emails to EML without depending on the original Outlook profile. You can select the required folders, including subfolders, rather than exporting everything.
The thing I would pay attention to here is the folder hierarchy. If the OST contains years of Inbox, Sent Items, custom folders, etc., you really don't want to rebuild that structure manually after getting the EML files. The converter keeps the hierarchy along with the attachments and email properties, which makes the output much easier to work with.
I’d still export a small folder first and open a few EML files in Thunderbird or whatever client you are moving to. That should give you a quick check that the message body, attachments and folder structure have come across properly.
09/14/2026 12:59 AM
MailsDaddy OST Converter tool is the best solution that offers user to migrate data from OST to EML file format. It keeps all mail formatting, header, inline images, attachments, etc. during the whole conversion process. The software has lots of features and functionalities to transfer data from OST to EML, MSG, HTML etc. The free demo version of the solution moves up to 20 emails from each folder.
09/26/2026 12:07 AM
The manual route works if the OST is still connected to an active Outlook profile, but it becomes impractical when the OST is orphaned or you need to process a large mailbox. In that situation, a direct OST-to-EML converter is more straightforward.
BitRecover OST Converter can process the OST directly and export the required emails to EML while retaining folders and attachments. For a large mailbox, I’d select only the folders you actually need rather than converting everything.
09/28/2026 7:51 AM
Are you trying to convert OST to EML format? If yes, then try RecoveryTools Outlook Migrator Tool to export OST to EML format. This application effortlessly convert Outlook OST files into EML format efficiently. Users can export multiple emails or entire mailboxes in single process. It help users to choose specific folders, emails, or mailbox items for OST to EML conversion. This application also maintains subject, sender, recipient, CC, BCC, dates, and other email details. It also convert emails along with their attached files & embedded content. It keeps original mailbox folder structure intact after conversion. Download free demo edition to learn more about the software.
10/08/2026 4:45 AM
You can convert your file from OST to EML with the manual method, but it is difficult when you manage a large number of files because the process of converting files is too long; you just convert the files one by one, and it consumes a lot of time. Instead of this method, I recommend an advanced tool, which makes the process of bulk conversion easier. The TrustVare OST to EML converter is capable of converting multiple OST files without the need for Outlook. The converter must maintain all the attributes of the emails, including To, From, CC, BCC, date, subject, attachment, and folder structures. In case of large mailboxes, bulk conversion saves a lot of time. The preview feature is also good for checking the selected folders before the conversion process and export.
10/22/2026 7:27 AM
If your OST file are healthy and connected with Outlook profile, so you can you can save your OST emails into EML format one by one using Save as option. Bu in case your OST file are corrupted damaged or orphaned, you need to use some dedicated tool like ViceVersa OST to EML Converter Tool. With the use of this utility, you can easily convert OST to EML format in just few steps. Also, you can easily access or import the resulted EML files in any supported email clients such as Thunderbird, eM Client, Apple Mail, etc.
Register to Reply 9 comments
Cameron (1); demetrioparrilla (1); mackjohn (1); olivia2028 (2); rowanfletcher (1); selnalarsen (1); somit (1); sonu2shukla (1)
