For Industrial Switchgears, VFDs, the MCBs (Miniature circuit breaker) according to IEC 60898-1 can be used satisfying the short circuit requirements or only MCBs according IEC 60947-2 is acceptable?
The main difference in IEC standard's application is only in the environment where the control circuit will be...
Which in my view means that you need to consider the maximum available power around the area where your control circuit will be installed and utilized..
Industrial environment which generally has a much higher available power levels that are readily available and present, in comparison to the limited power allotted and designated for the general household area of utilizations and/or applications.
