Previous in Forum: Recover Deleted SQL Server Records   Next in Forum: Industrial Measurement and Control Explained: How Level Sensors Enable Precise Level Monitoring in Tanks and Pipes
Why Do Diaphragm Pumps Have a Short Service Life?
06/29/2026 6:20 AM
Many conventional diaphragm pumps are made with lower-grade materials and simpler manufacturing processes. Under prolonged high-load operation, they are more susceptible to issues such as magnet demagnetization and motor circuit failure, resulting in a shorter service life.
To address these challenges, JD diaphragm pumps feature an optimized structural design and premium materials that significantly extend pump durability. With a service life of up to 10,000 hours, they provide a reliable solution to the common problem of limited diaphragm pump lifespan.
Want to learn more about JD diaphragm pumps?
Pathfinder Tags: ‘‘pump’’
