Rigid welded pipe connections are widely adopted in oil & gas, petrochemical and chemical processing plants. However, thermal expansion and continuous equipment vibration often create stress on pipe joints, which gradually causes seal failure and medium leakage.
Properly selected flexible piping components can effectively solve these pain points:
1.Stainless steel metal hoses: absorb thermal displacement and vibration between fixed pipelines and equipment
2.Custom rubber seals: adapt to different temperature and corrosive media to maintain bubble tight sealing
3.High-pressure hydraulic fittings & couplings: realize reliable connection of flexible pipelines
These flexible components are often matched with valves, pipe couplings to build a complete safe fluid transmission system.
We supply a full range of metal flexible hoses, hydraulic hoses, pipeline rubber seals and pipe fittings serving oil & gas, chemical, mining industries.
If you are looking for reliable flexible piping solutions for industrial projects, welcome to visit our website:www.lonsuc.com
