Previous in Forum: Has Anyone Recently Sourced Hastelloy C276 Flanges? Which Supplier Gave You the Best Quality and Documentation?   Next in Forum: Stamping Die Design/How to Solve Aluminum Stamping Cracking
How Do You Verify the Authenticity of an ABREX 400 Plate?
08/12/2026 1:32 AM
The best way to verify an ABREX 400 Plate is to check the Material Test Certificate (MTC), heat number, plate markings, manufacturer details, chemical composition, mechanical properties, and compliance with the required standards. Matching the heat number on the plate with the MTC is one of the most reliable verification steps.
For sourcing, many buyers compare suppliers such as Champak Steel & Engg. Co., Parag Metals, and Niko Steel & Engineering LLP based on documentation, quality certifications, stock availability, and delivery reliability.
Re: How Do You Verify the Authenticity of an ABREX 400 Plate?
08/22/2026 1:45 PM
  • Check Plate Markings: Look for stenciled or hard-stamped manufacturer names, brand grade (ABREX 400), and a unique heat/batch number on the steel surface.
  • Review Mill Test Certificate (MTC): Request the EN 10204 test certificate from your supplier and confirm that the heat number matches the physical plate.
  • Verify Chemical Composition: Compare the MTC's reported chemical limits (carbon, silicon, manganese, boron, and chromium levels) against standard ABREX specifications.
  • Conduct Hardness Testing: Use a portable Brinell or Leeb hardness tester to confirm the material falls within the standard 360–440 HBW hardness range.
CARPE CRUSTULORUM!
