Previous in Forum: How Do You Verify the Authenticity of an ABREX 400 Plate?   Next in Forum: What wall thickness and material grade are preferred for rotomolded plastic fuel tanks resistant to E5 gasoline
Location: Tianji Building, No. 8, Tairan 5th Road, Shatou Street, Futian District, ShenZhen,China
Stamping Die Design/How to Solve Aluminum Stamping Cracking
11/06/2026 5:00 AM
Hi everyone,
I am currently working on a stamping die design project involving aluminum sheet metal, but I've run into a persistent issue with material cracking during the forming process.
I suspect it might be related to the bending radius, material grain direction, or the drawing velocity, but I haven't been able to pinpoint the exact root cause yet.
To give you a better idea of the exact geometry, die structure, and the cracking locations we are experiencing, I have uploaded the specific design details and case study parameters here:
Has anyone encountered similar cracking issues with aluminum deep drawing metal stamping? What are your go-to solutions regarding blank holder force adjustments or radius optimization in the die design stage?
Any insights, formulas, or suggestions would be greatly appreciated!
Thanks in advance,
windward
metal stamping technical exchange
Re: Stamping Die Design/How to Solve Aluminum Stamping Cracking
11/06/2026 10:42 AM
Welcome to the conference room.
Whatever you intended to link to did not stick (does not work on my mobile device). Can you tell us your alloy? Overall dimensions, including flat blank and target thicknesses? Are the ‘innie’ protrusions formed after drawing, or have you built an articulated mandrel?
I cannot tell from the image… is this piece a candidate for spin forming in lieu of deep drawing?
11/17/2026 12:08 PM
I'd check the bend radius and grain direction first. Aluminum can be pretty sensitive to both during forming. The alloy and temper would also help narrow down the cause.
MalcAndCheese
11/17/2026 9:24 PM
You need to go through the possible causes one at a time, it requires meticulous observation and measurement....
Root Causes of Aluminum Stamping Cracks
  • Excessive Stretch or Thinning: High draw depths, sharp radii, or poor part geometry cause the side walls or stretch flanges to thin out and tear. [1, 2, 3]
  • Improper Tooling and Clearance: Worn cutting edges, misaligned upper and lower dies, or improper punch-to-die clearances lead to uneven edge work-hardening and splitting. [1, 2, 3]
  • Poor Material Flow and Wrinkling: Incorrect blank holder forces or improperly positioned draw beads restrict metal flow, causing the sheet to wrinkle and subsequently overstretch or split. [1, 2]
  • Machine Miscalibration: Ram parallelism issues or off-center die mounting cause one side of the part to absorb significantly more tonnage than the other. [1]
  • Inadequate Lubrication: Insufficient or wrong lubricant increases friction, driving up forming forces and localized heat. [1, 2]
How to Solve and Prevent Cracking
  • Adjust Tool Clearances and Radii: Increase tight bend radii and re-adjust punch-to-die clearances so the aluminum wall doesn't pinch or over-thin.
  • Modify Blank Holder Force: Balance or decrease the blank holder force and check draw bead layout to allow smoother metal drawing without wrinkling.
  • Calibrate the Press: Ensure ram parallelism, proper alignment, and even tonnage distribution across the bolster plate using documented press settings.
  • Deburr or Sand Edges: Grind or sand sheared blank edges prior to stretch-flanging to remove micro-fractures from the cutting phase.
  • Use Multi-Stage Forming: Break complex shapes into multiple progressive forming steps to distribute strain more gradually across the material.
  • Optimize Lubrication: Apply specialized aluminum-forming lubricants to reduce friction drag across critical draw zones. [1, 2, 3, 4, 5, 6]
Register to Reply 3 comments
Doorman (1); MalcAndCheese (1); SolarEagle (1)
