Previous in Forum: How Do We Move EMC from a Final Compliance Test to a Sequence of Engineering Design Gates?   Next in Forum: FANUC aiSV 40/40 SP1241 — Accel-only Intermittent, Gate Driver Suspicion
LV Switchgear - IEC 61439 - Temperature Rise
08/14/2026 11:58 AM
The specification says, " LV Switchgear Bus bar temperature rise shall not exceed 45°C under rated current".
The ambient temperature is around 45°C.
It means the maximum permitted operational temperature under normal service conditions is 90°C (permitted temperature rise + Ambient temperature).
As I understand IEC allows the maximum copper busbar operational temperature under normal service conditions is 105°C.( 35°C ambient + 70°C temperature rise).
Is there anywhere mention the derating factor for the stringent temperature rise than the IEC allowed 7070°C temperature rise?
Re: LV Switchgear - IEC 61439 - Temperature rise
08/14/2026 12:43 PM
“The specification says…”
Proper and professional business practice dictates that if a referenced model code (in this case, presumed to be IEC) is MORE restrictive than customer specifications, the model code should be used as a minimum.
Proper and professional business practice dictates that if a referenced model code (in this case, presumed to be IEC) is LESS restrictive than customer specifications, the customer specification should be used as a minimum.
Reply to Forum Thread
