Previous in Forum: HD-SDI Over Fiber Not Locking on Receiver Side   Next in Forum: Question for How to Leave the Distance for the Hold to Bending Line
MVME 6100 BDFAIL LED STATUS
08/20/2026 3:36 AM
Hello, We have MVME 6100 board installed in one of our equipment and we have LED BDFAIL active when equipments are working.
is this situation normal?
Best regards
Pathfinder Tags: BDFAIL LED STATUS
Re: MVME 6100 BDFAIL LED STATUS
09/10/2026 4:36 PM
Probably not. That's why it is on!
  • What does the Operation and Maintenance Manual say?
  • What was the outcome of the telephone discussion with the original equipment manufacturer?
09/15/2026 5:12 AM
Is the equipment still under the Original Equipment Manufacturer's product warranty arrangements?
What has been tried so far?
<...We...we...our...>
Are there other users nearby who can help?
Are there people in wider networking activities that can help over the 'phone?
09/16/2026 1:47 AM
Direct from the internet…
The Emerson / Motorola MVME6100 Manual defines the yellow BDFAIL (Board Fail) LED as an indicator that the single-board computer has detected an internal hardware failure, self-test error, or a system-level fault condition. Having the BDFAIL LED lit while the equipment is running is not normal and typically indicates that either a hardware fault has occurred on the board or software has explicitly asserted the fail signal due to a detected exception.
It is not reassuring that you do not realize something is wrong, unless your programmer was derelict.
Register to Reply 3 comments
