Previous in Forum: Foul Odor Two   Next in Forum: A Holiday Gift
seawater desalination
12/15/2007 9:09 AM
need some related expressions for designing an RO unit for sea water desalination.here we combine membrane technology and thermal energy...the separation is made by using temperature gradient...
Re: seawater desalination
12/15/2007 12:14 PM
Can you tell us more?
Gavilan
12/15/2007 10:46 PM
Hello
I am doing " RO Design ".You knoe at first you should define :
  1. Feed Flow Rate
  2. Permeate Flow Rate
Depending on this you will find the recovery . R= P/F
Then you will choose on of " Design Softwares " .I am using ROSA.You can easily downloaded from internet.
Then there will be instructions that can help you in understanding how you can make design for this.
I will be ready to answer you if you want anything.
Thanks & Best Regards
Eng Dania Moh Jamil
Location: Lenox, Massachusetts, United States of America
12/16/2007 8:26 PM
Thank you for sharing information about the ROSA resource offered by Dow/Film-Tec. What an incredible tool to learn more about desalination systems and Reverse Osmosis!
Why do you suppose Dow would offer this information for free on the internet to all, including their competitors?
APIX Pilot Plant Design Project - Member - New Member
12/16/2007 12:51 PM
suggest you consider a "greenhouse" set at a level that sea water is fed into a shallow blackened tub structure at high tide and drained out of the tub structure at low tide. The tub structure is enclosed in a transparent greenhouse type building where the slopping walls and roof would allow condensed water to run into troughs for collection in a sump. From the sump, the "distilled" water can be feed into any sort of pipeline for distribution. This is the simplest method and is very energy efficient since only energy required for operation is the sun and the pumps to distribute the water after collection. Of course, energy would be required to manufacture the tub and greenhouse structure, sump and pump(s). For electric power, consider solar cells and/or fuel cells.
chtank
12/17/2007 4:33 AM
There are so many playes in the market place that it may prove more economic just to buy one. They range in size from small hand-operated ones for the solo cross-Atlantic rower, to major municipal installations like the ones in Larnaca, Cyprus.
05/07/2011 2:31 AM
Canadian Clear has designed the most economical and efficient Seawater desalination plants to overcome the need for pure potable water for drinking and for industries. http://www.canadianclear.blogspot.com
chtank (1); Daniaobeed (1); desal (1); Gavilan (1); MillMatt (1); PWSlack (1)
