Previous in Forum: Megawatts per ton of steam coal   Next in Forum: How Do I Light Up My Jewelry?
Concrete reo Alternative?
12/16/2007 4:09 PM
Hi im hoping someone knows about stainless steel shavings which go in place of reo for structual concrete?
In need of a contact in Australia who might know something about this or where it may be purchased?
Carl
Re: Concrete reo Alternative?
12/16/2007 10:49 PM
Shaving will only give you compression strength not structural strength. it is use to reduce the thickness needed. Not the longitudinal strength.
If you laid a slab 100 x 5 metres it would crack through but if you loaded it over a 1 meter square with something heavy there is no problem.
As for shavings China is your only hope.
A Arnold Be MBA
12/17/2007 10:22 AM
With the price of stainless steel the way it is why would you want to use it in place of reo?
12/17/2007 10:35 AM
I have to agree with this guy. Stainless Steel costs are high. I would imagine this would make the concrete that uses stainless steel in place of sand or fiberglass would be expensive. Unless you were only pouring a small area but to purchase enough stainless steel for an area say the size of a slab for a home it would be pretty cost prohibitive.
12/17/2007 10:45 AM
Not strictly related but I do remember a company Columbus from S. Africa doing a lot of trials with 3Cr12, a virtually nickel free stainless, as rebar. The applications considered were particularly structures like bridges where there was a safety requirement and, potentially, a very long life. I am not sure who now owns the business. Could have been bought by Krupp or Thyssen.
Good Answers: 117
12/17/2007 12:42 PM
I used glass entrained concrete for my workshop floor slab. Still cracked. maybe I should have had a slump check done. So, not impressed by glass. Maybe bits of metal would be better?
I thought re bar is used to support tension loads, are you, like, assuming a layer of stainless wool mashed into the bottom of the slab? Tell me more about this cool new building method! Its totally new to ME!
12/17/2007 12:54 PM
Almost all new homes that are built on a concrete slab get a crack running through the slab. Even after compacting the ground before digging the trenches for footings and plumbing, after pouring the slab and building on it, the building itself puts stress on the slab. The ground still has some settling to do and the weak point in the ground will sink slightly causing the crack.
Australia - Member - New Member Popular Science - Cosmology - New Member Hobbies - Fishing - New Member
12/19/2007 5:39 PM
If you don't laugh, you cry.
Register to Reply 7 comments
Anonymous Poster (2); geomech (1); Janissaries (2); Raknruin (1); Yusef1 (1)
