Previous in Forum: FIBRALUR: Wood Shavings and Organic Substrates   Next in Forum: Design of Adsorber
m.m.a mono from scrap of acrylic
03/20/2006 6:58 AM
khaled writes:
How to produce m.m.a (methyl methacrylate) monomer from scrap of polymethyl methacrylate?
Re: m.m.a mono from scrap of acrylic
04/12/2007 2:26 PM
It can be done by Pyrolysis at 600ºC: the fumes obtained by this method are monomer + olygomers. They have to be sepparated by distillation under vacuum at low (about 60ºC) temperature and different values of negative pressure.
If to be implemented for industrial use, probably not usefull at all (too complicated and expensive)
If used to analyze the composition of an acrylic, you also have to use magnetic Resonance and The "glass point" for each component.
Reply to Forum Thread
