I do not know enough about this field to stop myself from posting this undoubtedly erroneous suggestion...
But I DO recall that manganese and palladium alloys have a remarkably high coefficient of expansion when heated.
So, comma, just mix a melt of the two of them, and the proper amount of (say) U235, and cast into a rod shape,
and upon cooling, the uranium will get closer, and more neutrons will be released, and, see, uh, the rod will stay at (say) 900 degrees for a LONG time.
(When it gets hot, it expands, and the molecules are further apart: the inverse when it begins to cool...)
So you drop this baby into your boiler, and use the steam to drive anything you want!
Every 5 years you turn in your somewhat depleted rod (and it's protective cannister) for a new one..
(If this worked it would already have been done. So why doesn't it work?)
