Previous in Forum: Polyethylene   Next in Forum: Checking Crome Plating Contamination
12 comments
Carbon Black
12/18/2007 12:45 AM
Can any one suggest how to improve blackness(Tint) of carbon black powder may by by addition of some pigment or any other process.
Best Regards
Rajesh
Re: Carbon Black
12/18/2007 3:56 AM
  1. Increase the proportion of carbon black in the material.
  2. Reduce the particle size.
Re: Carbon Black
12/19/2007 2:43 AM
Dear Sir,
Thanx for your valued comment , I know as we decrease particle size surface area increases an it gives better blackness , but as particle size is decreased carbon becomes light in weight and fly loss is more , as we do mixing in open rolls .
I am well aware of all grades of carbon black but price is a factor too as in our country competetion is very high , may be you can give some other advice.
Re: Carbon Black
12/18/2007 4:27 AM
Dear sir,
If u want to improve the properties of CB you can try the suggestion below:
1. U can increase the CB loading on ur compound..but it have limitation that if the loading to much it will drop the properties of ur product
2. U can use the CB with small grade N330...this particle about several nanomicro...so this particle will have high surface surface area n give high properties...
3. You can use hybrid filler if u consider the cost
Re: Carbon Black
12/18/2007 4:30 AM
For ur information..usually pigment used as colourant for ur product... some process..maybe u can use any treatment to improve the properties of CB
Re: Carbon Black
12/18/2007 10:06 AM
Carbon Black pigments come in a veriety of particle size and surface treatments. Some CB has a yellowish undertone, some has a blue undertone. Surface treatments may be added, for instance a surfactant treatment for use in water base paints.
You can try shifting the undertones by adding yellow or blue pigments but it is not easy. Sometimes an addition of black iron oxide will help.
Contacting the pigment supplier can be helpful.
Re: Carbon Black
12/19/2007 2:40 AM
Carbon black pigments are the deepest blacks in the market, but for a proper color development is imperative to mill them. This process has to be made with proper dispersing additives and resin binders. There are many grades available but the best are the ones with high specific surface and high oil absorption values. However, if milled pigment is not black enough for your purposes, in some applications blackness can be improved by adding black dye.
RMP
Re: Carbon Black
12/19/2007 3:19 AM
The "blackest" carbon black is the soot obtained by dry distillation of bamboo.
Popular Science - Weaponology - Cardio-7
Re: Carbon Black
12/19/2007 10:13 AM
Contact one of the pigment manufacturers who supply pigments to the paint companies. Start with Google for Pigment Suppliers.
Re: Carbon Black
12/20/2007 9:49 AM
Make a masterbatch with high content of very fine carbon black,
perhaps N550 or 600, then add portions of this into your regular process. This will minimize your loss of CB.
It will also be easier to mantain an even quality.
Re: Carbon Black
12/20/2007 4:42 PM
There are too many variables regarding the CB topic, I suggest visiting Shepherd Color Company (based in Cincinnati, Ohio) at www.shepherdcolor.com. They are the world's largest family-owned pigment manufacturer and they have an excellent tech staff to help you.
Re: Carbon Black
12/25/2007 12:44 PM
Dear Rajesh,
You have not mentioned the Product Type in which you are using C-black i.e.A Plastic article, A Paint or Coating Film ,Rubber etc.
There are few suggestions you can weigh them to your best :
(1) Increase the % Proportion of C-black grade you are using to the maximum possible
in your Formulation.
(2) Change over to very fine and High Jet Black Grades ,like FW200 of DEGUSSA.
(3) Try and use some effective Dispersing and Wetting Agents and make sure you are using the pigment grade to the maximum - possible extent to develop the jet blackness .
Many times it is observed that a bad formula can waste the BEST of the grades , if correct grade and or dosage of additive is not selected carefully.
(4) Equipments and Machines used by you for mixing and or Dispersing the Black Pigment in to your system also plays important role. Please look at them and make sure you are using the correct procedure and conditions to develop Jet blackness to the maximum extent.
Please try these options.
PANKAJ VYAS
Re: Carbon Black
01/26/2008 3:28 AM
If you look at the spectrum you will find that no reflection (black) will occur after the infra red (brown black) or before the Ultraviolet (blueblack) so to get the best black all the spectrum must be absorbed. Carbon black is in the brown-black range so you need to add blue pigment or dye to ensure that no light is reflected.
You will of course need to find the black with the lowest reflection in the first place.
Les Fisher FTSC (paint consultant)
You can always tell the pioneers - they are the ones with arrows in their backs.
Anonymous Poster (6); Cardio07 (1); hazman (1); PWSlack (1); Snuffie (1); zunaida (2)
