Previous in Forum: Automatic, Manual, and Cascade Control Mode   Next in Forum: Want To Force 4-20mA With 12V Battery
valve size & type
12/18/2007 6:10 PM
1-There is a valve spool for the X-Ray guage measurement in our rolling mill system,now Pressure drop across the valve is 2 bar, the cooling water return line outlet water is got to have the back pressure of 1/2 a bar at the outlet, I have selected a 1/2 inch Globe valve is that OK?
2- Supply water of 7 bar going to the same valve spool system, we need a valve type & size to provide inlet supply water to valve spool as flow of 0.6M3/Hr and pressure of 2.5 bar. I have calculated Kv which has come out to 0.282, now I have different tables but not showing the valve size/type, could you please show me the calculation. water is plant water @ 25 degree C , you can ignore the tempreture.
Cheers
AT
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
Re: valve size & type
12/20/2007 10:10 AM
From what I recall...Pressure drop across the valve wide open should be 1PSI. The diameter of the piping on which the valve is installed should not xceed 1.5 times the diameter of the selected valve. Also, there are infinitesimal plug designs; choose one that is close to linear flow and rted pressure capacity for your system. If not you will blow the packing material from the stem. Stems come and are selected according to size. I can only guide you I cannot solve your problem; I have not done this type of work in almost 15 years...
Also, I worked in this field when it was still the English system; lbs/ft/sec
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
12/20/2007 10:26 AM
