Previous in Forum: Machines For Use In Indian Enviornment   Next in Forum: HSS Annular Cutters and TCT Annular Cutters
Vacuum Pump
12/19/2007 4:09 AM
we want to used vacuum pump for molasses and cromore fines slurry lifting with head 12meters.
It is possible? or Not.
If possible please let me know type and model & cost of the pump, where it is available for immediate purchase.
by
ramachand
Re: vaccum pump
12/19/2007 4:36 AM
Need to know the density of your product to give a definitive answer, but my feeling is that it is not possible in one stage.
Re: vaccum pump
12/19/2007 5:23 AM
You can only ever suck to 1 atmosphere... (~1bar)
Can't you have the pump lower down and push the stuff rather than sucking it...you can get a positive pressure of several bar very easilly...
Re: Vacuum Pump
12/19/2007 8:31 AM
If you have steam, why not use a piston pump that has steam cylinders on one side and pump cylinders on the other. I think Worthington makes them and maybe Platt Pump. They are used everywhere to pump high viscosity materials and come in all sizes. One sugar refiner in Hawaii use them as large as 18" bores.
Peace be upon you.
Re: Vacuum Pump
12/20/2007 4:56 AM
Del and others are correct. It needs to be pumped rather than sucked.
Low-shear pumps are the sort of things to look for. Consider:
  • Lobe pumps
  • Gear pumps
  • Peristaltic pumps
Re: Vacuum Pump
12/20/2007 9:28 PM
Why not use an airlift pump instead? You have no chance with a vacuum pump.
India - Member - New Member
Re: Vacuum Pump
12/21/2007 2:17 AM
it would be difficult to let u know the exact specs without knowing the full deatail of ur pumping medium(like viscosity,density,temp,pressure etc etc)
why you want only vacuum pump ? i thk gear pump will also a good option for you ask to pump vendor with full detail he will better help you
good luck
Good Answers: 50
Re: Vacuum Pump
12/24/2007 2:08 AM
The great molasses disaster of January 15, 1919..
Register to Reply 7 comments
gaiatechnician (1); JohnDG (1); PWSlack (1); santoshmit (1); Skelley (1); user-deleted-1105 (1); vermin (1)
