Dear all,
In AFBC boiler of 70 tph capacity we are facing a problem of Economiser coil erosion specially in the straight portion near the inlet header. This economiser is a integrated type which located inside the furnace. The economiser coil connected to the inlet and outlet header passing through the rear water wall tubes. The flue gas from furnace take a U-Turn and passes on to this economiser. The fuel being used primarly is high ash content coal and Rice Husk is also fired to an extent of 15% of total fuel requirement.
I would like to know the probable reason of erosion of tubes.
Why it is eroding at only at Eco inlet header side since other portion of eco coil is ok.
Please note that the plant runs always on full load.
