Previous in Forum: Butterfly Valves   Next in Forum: process Instrumentation technology
Equation For Orifice Plate Used
12/21/2007 1:42 AM
an orifice plate is used to measure gas flow through D/P cell. However, when I checked the configured equation for calculation toatiser value I found the equation configured as
comp flow = flow measure * sqr(comp-factor)
is the above equation is correctly configured.
the D/P cell meter is not conggured as SQR out put value.
Re: Equation for orifice plate used
12/21/2007 6:00 AM
Differential pressure across an orifice is related to the flow by a square root function.
Re: Equation For Orifice Plate Used
12/21/2007 11:32 AM
flow at std conditions = Dp^.5 * Press^.5 * Constant
12/22/2007 12:21 AM
http://www.engineeringtoolbox.com/flow-coefficients-d_277.html
For more detail, check any fluids book or outline.
12/22/2007 12:45 AM
If you are using an orifice meter then
mass flow = constant * (P/T)^0.5 * (Diff pressure across orifice)^0.5
Take care of units used.
Good Answers: 18
12/22/2007 2:10 PM
This is likely the best form of the equation to use for gas flows. By all means, verify the units in the equation.
agua_doc (1); Anonymous Poster (1); moon161 (1); PWSlack (1); vicini (1)
