Previous in Forum: Torque measurement   Next in Forum: Feeler Gauges for Motorcycle Valves?
Friend of CR4
Water Pump to Operate in a Close Loop System
03/23/2006 8:16 AM
candyman writes:
I need a water pump to operate in a close loop system. The pressure in the system is about 50psi. but, there would be only about 10psi. of head pressure. The pump needs to be very reliable but would run only about half the time. 110v. ac or less would be good. The product pumped would be water with a temperature range of from 50 degrees to 150 degrees. This would be a low volume pump and would need to be adjustable. The pumped volume would be about 2 or 3 gpm. The connections should pipe or equivalent.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Good Answers: 19
low volume pump
03/23/2006 11:07 PM
My first reaction would be to say check out Bell & Gossett or Taco pump websites for product selection. What kind of adjustmentss are you wanting to make? Why adjustable and on-off operation? Is this temperature control or mixing operation?
Re:low volume pump
03/24/2006 10:08 AM
Grundfos Pump has the pump you need. www.us.grundfos.com
Good Answers: 11
Re:low volume pump
03/27/2006 10:00 PM
This sounds like a solar system circulating pump. Grundfos do indeed make one for this application and the control sytem. Grundfos and Lowarra also make variable speed drives for pumping systems. Give Global Spec a go.
Re:low volume pump
04/26/2006 8:49 AM
I an allso looking for a pump and a sestem to het up water for large clam shell molds that will only cost me about 1usd or leas to het up a 10 feet clam shell mold what cam you do for me
Good Answers: 11
Re:low volume pump
04/26/2006 10:31 PM
There are a group in Brisbane working on storage of Solar heat, I'll need their permission before I give out information though. Their prototype stores about 100kwh per day. It can be scaled, but I don't know by what factor.
Re:low volume pump
04/27/2006 8:47 AM
to 4119(485) when do you think this info will be avelibal and the cost of prdution need feed back or int lenk to aus
Register to Reply 6 comments
Anonymous Poster (1); Emjay4119 (2); Ried (1); suchi (2)
You might be interested in: Hook and Loop Fasteners, Loop Powered Devices
