Previous in Forum: Bed Ash Cooling system   Next in Forum: Info about pneumatic controller design technology?
Thermal Ice Building Chillers
12/21/2007 3:17 PM
Has anyone heard of using a Centrifigal Chiller to make Ice for thermal cooling for Air conditioning, basically off peak cooling? The ones I have installed have always been reciprocating or screw compressors.
Re: Thermal Ice Building Chillers
12/21/2007 4:37 PM
Centrifugals will not work in this application according to the DLT application manual. they can't pull down to ice building temperatures, hope this helps you.
12/22/2007 12:00 AM
No, most centrifugal compressors do NOT have sufficient compression ratio, they generally only operate between 35deg F and 85 deg F.
12/22/2007 12:13 AM
hi there ;
centrifugals are traditional used for the chilled water temp range
scrolls tend to werk in a narrow amp range,bad when ice builds up / amps hold up even though suction pressure goes down /
a mix of scroll and reciprocating compressor seems to the most economical way / scroll for hi temp , reciprocating compressors for low temp /
12/22/2007 1:57 AM
I suggest to contact Trane Company, they can assist you on your requirements.
Trane offer Ice storage production from screw compressors and to CTV chillers.
Should you need further info particularly Trane Chillers/product application, please contact me at My Cell: +971502487606.
nlp
12/24/2007 6:35 AM
Thanks for your feedback, this confirms my suspicions.
Merry Christmas
12/30/2007 12:50 AM
PipeIt: Contact Dunham-Bush Manufacturer. they are the expert of this technology in the market today!
Happy New Year
Jojie_oak
Register to Reply 6 comments
jojie_oak (1); KLYSTRON (1); nelson1 (1); philiplyon (1); pipefitter3524 (1); pipeit (1)
