I wonder where I could get Dimensions & Specifications for Standard Rolled Sections (I-beams, channels & angles) on the web. All I really need are the leading sizes (webs & flanges), area of section and weight per foot/meter. For this basic info that I actually require, buying standards giving detailed dimensions and properties is too expensive. For instance, I propose using a 600mm x 210mm standard I-beam on a loading frame that I am making. All I am interested in knowing is the area of section and the weight per meter. What are the other standard sizes available for I-beams, Channels and Angles?
