Previous in Forum: bus bar rating ?   Next in Forum: how to calculate system fault MVA ?
10 comments
what may be d reason??
12/30/2007 9:10 AM
what may be d reason of taking different currents of two motors of different rating using at same work load????
we have 2 motors one having rating 30 kw carrying current 31 A & other of 18.5 kw rating carrying current 26A under same work load????
Re: what may be d reason??
12/30/2007 12:21 PM
Because Slip % are different- due to cosΦ differences --with slightly different active Torque( because speeds are definitely not same-although you did not report this) .
12/31/2007 12:51 AM
Still it is not clear to me. both d motors have same rpm 985 n are driven by vfd at 45hz. how their slip is different.
12/31/2007 6:42 AM
Think losses.
BNDas
12/31/2007 8:07 AM
Think losses? ?
01/03/2008 9:59 AM
if the motors has same p.f. & same efficiency then under same load dey draw different currents? is it true ??? if it is den y ??? if u say the losses will be different ..then tell me y losses will be different???
01/03/2008 11:01 PM
read other comment
BNDas
01/03/2008 11:03 PM
Study text book and learn why motor losses are different at differant rating.
BNDas
01/06/2008 10:00 AM
Motors have efficiencies at full , three fourth , half and 1/4 load as well power factor.Full load eff and Pf are higher and motor operates with a better eff and pf.Obviously the 18.5Kw motor is operating near full or at higher load compared to the 30Kw.So operating at lesser load,with a poor eff and pf 30KW is drawing a higher current.Further the driven equipment should be identical for this comparison.One cannot be a pump and other a fan.pl give full details to give more accurate answer.The no load current also will be higher for 30 kw Check the test certificates.
01/06/2008 11:15 PM
Efficiency changes at different % of load is due to losses. Magnetic loading also changes w.r.t load requirement, causing change of p.f. You can refer to some motor design book, like Golding etc to explore more on this topic.
BNDas
01/09/2008 9:51 AM
hi friend.......thx... u have provided good information...as u wana know abt. exact loading...Both d motors have same lading.. both are driving a fan which supplies air to the plant...welll u have cleared my point....
Register to Reply 10 comments
biswanath.das (4); MUKULMAHANT (1); nesubra (1); sandeep (4)
