Previous in Forum: HVAC System   Next in Forum: Roof on Compressor Installation
Engineering Fields - Piping Design Engineering - New Member
Incoloy 800H & Inconel 601 materials
01/02/2008 9:02 AM
Where can I find the details of Incoloy 800H & Inconel 601 materials?
Regards,
Sabir
Re: Incoloy 800H & Inconel 601 materials
01/02/2008 9:19 AM
... Google.
Good Answers: 19
01/02/2008 11:31 AM
www.vdmaustralia.com
Good Answers: 94
01/03/2008 4:39 AM
Inconel 601
Inconel 800
took about 45 seconds in Google
10/29/2008 5:26 AM
inconel 601 plate
9.35T * 2000mm * 4000mm 1ea
10/31/2008 9:08 AM
Very interesting site, WIGGIN Special Products: http://www.specialmetals.com/products/ with both "Technical Bulletin" and "Technical Papers" in PDF formats for each alloy.
MONEL® alloys
INCONEL® alloys
INCOLOY® alloys
MONEL® alloy 400 INCONEL® alloy 600 INCOLOY® alloy 800
MONEL® alloy 401 INCONEL® alloy 601 INCOLOY® alloy 800H/800HT®
MONEL® alloy 404 INCONEL® alloy 601GC® INCOLOY® alloy 803
MONEL® alloy R-405 INCONEL® alloy 603XL INCOLOY® alloy 825
MONEL® alloy K-500 INCONEL® alloy 617 INCOLOY® alloy 832
Nickel/DURANICKEL® alloys
INCONEL® alloy 625 INCOLOY® alloy 864 ™
Nickel 200 INCONEL® alloy 625LCF ® INCOLOY® alloy 890
Nickel 201 INCONEL® alloy 686 INCOLOY® alloy 903
Nickel 205 INCONEL® alloy 690 INCOLOY® alloy 907
Nickel 212 INCONEL® alloy 693 INCOLOY® alloy 908
Nickel 270 INCONEL® alloy 706 INCOLOY® alloy 909
DURANICKEL® alloy 301 INCONEL® alloy 718 INCOLOY® alloy 925™
BRIGHTRAY® alloys
INCONEL® alloy 718SPF™ INCOLOY® alloy 945
BRIGHTRAY® alloy B INCONEL® alloy 725 INCOLOY® alloy MA956
BRIGHTRAY® alloy C INCONEL® alloy 740 INCOLOY® alloy DS
BRIGHTRAY® alloy F INCONEL® alloy X-750 INCOLOY® alloy 020
BRIGHTRAY® alloy S INCONEL® alloy 751 INCOLOY® alloy 028
BRIGHTRAY® alloy 35 INCONEL® alloy MA754 INCOLOY® alloy 330
INCONEL® alloy MA758 INCOLOY® alloy 25-6HN
INCONEL® alloy 783 INCOLOY® alloy 25-6MO
INCONEL® alloy N06230 INCOLOY® alloy 27-7MO
INCONEL® alloy C-276 INCOLOY® alloy A-286
INCONEL® alloy G-3
INCONEL® alloy HX
INCONEL® alloy 22
INCONEL® alloy 050
NIMONIC® alloys
UDIMET®/UDIMAR® alloys
NIMONIC® alloy 75 UDIMET® alloy 188
NIMONIC® alloy 80A UDIMET® alloy L-605
NIMONIC® alloy 81 UDIMET® alloy 520
NIMONIC® alloy 86 UDIMET® alloy 720
NIMONIC® alloy 90 UDIMET® alloy D-979
NIMONIC® alloy 91 UDIMET® alloy R41
NIMONIC® alloy 105 UDIMAR® alloy 250
NIMONIC® alloy 115 UDIMAR® alloy 300
NIMONIC® alloy 263
Other Products
NIMONIC® alloy 901 Ferry® alloy
NIMONIC® alloy PE11 NI-SPAN-C® alloy 902
NIMONIC® alloy PE16 Waspaloy
NIMONIC® alloy PK33 INCOCLAD® 671/800HT®
NILO®/NILOMAG® alloys
INCOCLAD® 625/Steel
NILO®alloy 36 Nitinol alloys
NILO®alloy 365 Electroformed Nickel Foil
NILO®alloy 42 INCOBAR® & DEPOLARIZED® nickel anodes
NILO®alloy 48 INCOTHERM® alloy TD
NILO®alloy K
NILOMAG® alloy 77
03/06/2013 7:02 AM
Thanks for the post; you can also check out Barcelona-based, The Alloy Valve Stockist, for valves in these exotic alloys.
Working with corrosion-resistant valves for the petrochemical industry.
12/04/2010 2:46 AM
Hi Sabir....
We deals in inconel products such as pipes & tubes, round bar, plate, sheet, flanges & so on. We are specialized in nickel alloy, monel, hastelloy & steel products.
Rgds,
Femi
Register to Reply 7 comments
Abdel Halim Galala (1); Anonymous Poster (1); ducon (1); JohnDG (1); Nigh (1); pfeinstein (1); RegentSteel (1)
