Previous in Forum: wind load calculation   Next in Forum: Busbar Manufacturers And Suppliers GCC
Which Material To Choose??
01/04/2008 2:47 AM
Please help me on which material and manufacturing method to choose for the making of table clocks in the shape of a clock tower to be given as a sovenier. Also please help me if you know some manufacturer for the same in India. The amount got to be about 1000 and has to be less than Rs.200 per piece.
Re: Which material to choose??
01/04/2008 2:58 AM
There is way to little information here, please do more research first and make your thoughts clearer.
Souvenirs come in all sorts of materials, wood, metal, jewellery, plastic.
Clocks can be just models or working items that tell the time.
Clock towers can be real big or rather tiny.
Failing giving us more info, just try to google souvenir manufacturers India, who knows!
Re: Which Material To Choose??
01/05/2008 1:26 PM
I have the ability to design & create such objects in polished marble or onyx with analog clock faces installed. Clock sizes range from 1 1/4" to 3". I'm just a country boy so you'll have to explain to me how many US dollars equals Rs.200.
Remembrance is the golden chain that binds our hearts together.
01/28/2008 8:34 AM
Can supply a special Bamboo -bottom closed/open-- Outer diameter 120>140 and wall thickness ~8mm. Height to next knot can vary 500>600mm Machine cut/polished/varnished. Or let us have your Drawing/
Possible to supply 1000 pc in 1 month . Each @150/- plain --- Ex Guwahati by Speedy train to Gujarat.
case491 (1); MUKULMAHANT (1); rockshop (1)
