If the power in is the same as the power out, roughly, then the current needed at the 12 volt side is 10 times what the output current is at 120 volts.
It will be a little more due to losses.
Power in = Vout/Vin x Power out for resistive loads.
Say: power in = 120 watts @ 12 volts > Iin = 10 amps
Power out = 120 watts @ 120 volts > I out = 1 amp.
Hi there,
Just popped onto this thread to perform the CE Quality audit on your post in accordance with EN blah blah blah. It seems that your thread is compliant regards emitted interferrence but seems to be susceptible to interfurrence (from cats mostly).
I think the appropriate corrective action would be to ignore this post entirely.
As a young teen (in the fifties) I had a 48 Chevy. Had an AM radio, but not many stations that could be picked up.
I had acquired a 12V to 120/240 V inverter somewhere along the line. I, as many or us back then did, had a portable turntable (for younger folks, a RECORD PLAYER). 45s were big then. Elvis's "Hound Dog" and "Love me tender" were gold. Anyway, I had the bright idea of putting the record player in the back seat and spinning a disc while me and girlfriend were smooching. It gets better!
On the way to pick her up I thought I'd try it out. I placed the record on the turntable, then drove off slowly ready to place the needle on the record. I reached back and switched the inverter on- to the 220 V position! What followed was smoke galore!
That record player became instant toast. I think I called my girlfriend and made up some lame excuse why I had to cancel since I had told her of some new and exciting invention I had.
(A lesson in what not to do with an inverter)
All worthwhile programmers know that constants always vary.
Ah the horrid stench of burning recod decks.. brings back memories...
Recipe for smoke..
Take 2 mono 'record players'.... put a stereo cartridge in one... wire second chanel to deck two.... fine... we have stereo folks .
Decide to remove the now unused deck 2 by removing it and the armature of the motor...
Smoke (I was only 18) and that's what started me on the path to electronics design...maybe I'll get the hang of it soon .
Step 1: Mortgage your house and buy a 105 MB hard drive (yes megabytes guys and gals, and my first hard drive was a whopping 10 - yes ten - no more zeros).
Step 2: Connect all cables while wearing earthed boots, gloves, wriststraps - I'd have earthed my whanger if I'd had a large enough crocodile clip ;-)
Step 3: Test every possible connection with a digital multimeter, which actually cost more than the hard drive, so double nervous depending on what blew up what.
Step 4: Marvel at technical proficiency as the drive boots, Ontrack is installed to con the MSDOS operating system, and software is installed.
Step 5: Triple double check all connections before reassembling machine.
Step 6: Final connection is a poxy 2-pin black and red, from the case LED to the ouput LED connector on the HD. Polarity - check. Trace cables - check.
Step 7: Watch in wonder as the hard drives erupts in smoke, sparks flying, connectors melting, power supply fizzing in sympathy, wiring smoking, heart stopping.
Step 8: Curse the designer who decided to make the 12volt feed to the processor fan the same colour and connector as the connection to the front panel LED.
Step 9: check warranty to see if driving 12 volts into the LED output of a hard drive is covered under warranty. Actually, it was!
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
I remember a car that came out back in Elvistime that had a fold down 45 player under the dash. You should have got one of those - it was the cat's pajamas.
I have never heard of that one. Do you recall make & model? Just curious.
Wouldn't have made a lot of difference at the time though. Was barely able to afford those 45's. Me & best friend saved/scrounged up $25 to buy a guitar. We shared, and learned together, to play basic chords like C, F & G7th so we could play songs like "Love me Tender", "Raunchy", etc.
True story: Me and said best friend actually used liquid black shoe polish to dye our hair for that "Elvis" look (well, really, to impress the girls). I understand that there are, to this day, pics floating around of that episode.
Just because you asked(?), we did not pick up a date with our dyed hair! We did, however, get four people in the trunk, and pay for two, to get into the Drive-in movie (of course it it was an Elvis movie, what else).
Believe it or not, we kids had real fun!
-John
I don't remember the model, but a quick google came across a site that purports to repair those old things.
And I found this:
Automobile Phonograph
In 1955, an automobile phonograph system was developed.
57 A special 7-in record, turning at 162 rpm, and
containing up to 45 minutes of music, or one hour of
speech on each side was used. 500 and 600 grooves/in
were employed and the stylus of 41-mil radius exerted a
force of approximately 2 grams on the disk. The pickup
cartridge was mounted in a balanced and heavily
damped arm, and pivoted to permit handling records
without scratching. The phonograph was suspended on
elastic mounts to permit operation in the moving
vehicle.
"The pickup cartridge was mounted in a balanced and heavily
vehicle."
I had actually tried mine stationary at the proper 110 V setting before I blew it up on 220 V while driving. I realized that keeping the needle in the groove would be a problem so I taped two pennies to the arm before driving off into the record player sunset.
Looks like the guys you mentioned put a little bit more forethought into it. BUT, we were but teenagers once!
-John
I just went back and read a lot of the comments on the link. As you say, a lot of interesting comments there. I did not know about those things that went on. Must have been preoccupied with life or something.
"Alas, problems abounded with the system: Records skipped as the car encountered uneven surfaces. And an exclusive content arrangement with Columbia meant that drivers could listen only to artists signed to Columbia Records."
As noted by the experts, record skipping was a genuine problem. Before my player's untimely demise, as I said earlier, I did conquer, somewhat, with the two penny solution. I think I failed to mention earlier that I did test drive the 1950 Oldsmobile with back seat record player, with the weighted needle arm, successfully before driving off for my never-to-be date because of my $%*&*5** carelessness! Needless to say, I did not score that day!
Good thing that I am reading, from time to time, this forum. I tried to supply a record player with a DC to AC step up transformer, but it seems that I didn't use the right voltage. I connected a 12V battery to the primary and, after a minute or so, it started to smoke. My taylor told me that I should have used a 8.8V batttery.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
One question regarding the aforementioned "record player":
Where in the world would a teen, intent on impressing a lovely date, with a newfound invention, POSSIBLY locate an 8.8V battery??? Wait! I didn't think about Mars! At that time aliens were suspected of, perhaps, be hanging out there. They probably hoarded all those 8.8V batteries for use in their ion engines. Wellll, they had to be somewhere didn't they?
Just a pedant's joke. I used a step up transformer for a DC to AC "operation". Supplying the primary with DC, wishing to get the AC output (of coarse, of any desired frequency). And a 8.8V battery was the clue. Yes, to hermetic...I guess.
Correctly would be: a DC to AC inverter
