We are a welded structure fabrication company and we are asked to build a small 2000bar pressure vessel (to be used as a static, pressurized air storage vessel in ambient condition) as per design provided by our customer who designed it as per ASME BPV, Section VIII, Div.2 code of 2005. However the customer is now asking that hydrostatic pressure test be carried out at a test pressure of 143% of the MAWP (2000bar) once the pressure vessel fabrication is completed. The ASME code of 2005 requires this hydrostatic pressure test be done at 125% overpressure only. But the customer is asking why we should not follow the 2007 BPV code of hydrostatic testing at 143%? We dont want to do that and I strongly feel that there is no need to go beyond 133%, esp. when the same code in 2005 did specify only 125% overpressure. I wonder whether anyone with experience in this line can throw some light on this problem? And, why at all ASME code has come up with this 143% overpressure, and whether really the code intended this to be applied to this level of pressure i.e.2000bar pressure vessel.
