Previous in Forum: How to calculate the energy output of a pma?   Next in Forum: starter
temperature
01/06/2008 2:23 PM
Hi
I simulated an amplifier and found that the gain varies with temperature. i.e the gain was 15k at 0C and 10k at 90C
Re: temperature
01/06/2008 3:16 PM
What opamp did you use and what are the values of the resistors around it?
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Good Answers: 54
Re: temperature
01/07/2008 5:10 AM
and your question is...?
"Simulated" means virtual or not real. How can your amplifer be affected by temperature if it's not real?
Re: temperature
01/07/2008 8:10 AM
this is my circuit, I simulated it with PSpice. So because of the change made in the resisters' values the gain varies with temprature, yes?
Re: temperature
01/07/2008 12:47 PM
There is not biasing for the input transistors. Also, I cannot see what device is between the collector and base of the transistor in front of Q3. Run a DC analysis over temp.
Good Answers: 54
Re: temperature
01/07/2008 6:51 PM
There is no device between the collector and base of that transistor. It's a short circuit. That blob on the line is the label for the transistor which I cannot read anyway.
In addition to the lack of biasing, both power supply rails are at positive potential! The (+) side of the batteries are both connected to both rails. What gives?
Re: temperature
01/08/2008 6:59 AM
Ha, ha...I didn't even look at the generators. Than, the first circuitry would be a regular current mirror. Our friend is no more interested in his circuit...
Anyways, your eyes are better than mine.
Register to Reply 6 comments
indel (3); m2babaey (1); Vulcan (2)
