Previous in Forum: kVA Off a Pole-Bolted xfrmr   Next in Forum: Fan Running With 1/2 Current.
Duty Cycle
01/09/2008 11:25 AM
i wana know about the duty cycle...on electrical equipments duty is always written like Duty= s1.. i know duty cycles are from s1 to s8. what does it mean duty s1??? similarlly S2, s3 ...etc
Good Answers: 40
Re: Duty Cycle
01/09/2008 2:26 PM
Duty cycle refers to the time when a motor is doing 'work'.
From Here http://answers.yahoo.com/question/index?qid=20070820053208AASG63E
and Here http://books.google.com/books?id=8mQewRR_3q4C&pg=RA1-PA54&lpg=RA1-PA54&dq=electrical+duty+cycle+s1&source=web&ots=TcpNtxF5j-&sig=U-8BpKyH9BshzD-_MuCldbNundQ#PRA1-PA56,M1
"The eight - S1 - S8 - IEC duty cycles of operating electrical motors
IEC (the International Electrotechnical Commission) uses eight duty cycle designations to describe an electrical motors operating conditions:
S1 - Continuous duty. The motor works at a constant load for enough time to reach temperature equilibrium.
S2 - Short-time duty. The motor works at a constant load, but not long enough to reach temperature equilibrium. The rest periods are long enough for the motor to reach ambient temperature.
S3 - Intermittent periodic duty. Sequential, identical run and rest cycles with constant load. Temperature equilibrium is never reached. Starting current has little effect on temperature rise.
S4 - Intermittent periodic duty with starting. Sequential, identical start, run and rest cycles with constant load. Temperature equilibrium is not reached, but starting current affects temperature rise.
S5 - Intermittent periodic duty with electric braking. Sequential, identical cycles of starting, running at constant load and running with no load. No rest periods.
S6 - Continuous operation with intermittent load. Sequential, identical cycles of running with constant load and running with no load. No rest periods.
S7 - Continuous operation with electric braking. Sequential identical cycles of starting, running at constant load and electric braking. No rest periods.
S8 - Continuous operation with periodic changes in load and speed. Sequential, identical duty cycles run at constant load and given speed, then run at other constant loads and speeds. No rest periods."
Re: Duty Cycle
01/10/2008 2:26 AM
Dear friend,
You can refer IS:325 wherein all required details are given. Or else, you can refer catalogue of a reputed manufacturer like Siemens, Crompton Greaves, ABB, BBL, Kirloskar Electric etc.
D.D.DESAI
Register to Reply 2 comments
