Previous in Forum: Selvedge printer   Next in Forum: Looking for manufacturing process information
Plate Welding Thickness
01/10/2008 10:32 AM
I have heard the terms light, medium, and heavy weldments... can anyone provide guidance to the material thickness ranges associated with each of these three terms?
Re: Plate Welding Thickness
01/11/2008 7:53 AM
These are terms from shop language.
Not conforming to any standard.
Light will be upto 3mm thick,Med will be upto 10mm and Heavy above 12mm
While on the subject it is better to think about Root gaps kept deliberately -both for fillet welds and for the once-through pass:
http://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=13851 gives some thoughts.
Good Answers: 18
01/11/2008 12:35 PM
As my friend MM has suggested , the terms mentioned by you are of shop language for fillet welds.
To add further to what he has said, any butt joint up to 10 to12 mm thickness plate will have a reinforcement of 1.5 mm with tolerance of 0.5 mm on higher or lower side. beyond that , it could be up to 2 to 3 mm as it is not practical to control the build up to close tolerances and heavy build up will not contribute towards its joint strength and lower build up will not carry the required load.
For fillet welds, the minimum leg length could be 3 mm or so and for any load bearing structure, the leg is designed to have a weld equal to 0.75 times the thickness of plate used. For non load bearing it could be 0.38 of the thickness used.
Hence there is no such light, medium, or heavy weld-ments. It all depends upon the thickness of the plates used.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
Register to Reply 2 comments
