Previous in Forum: Stop rust from coming out of steel profile   Next in Forum: ANSI Flanges allowable load
Digital indicator (drop gage) works
01/10/2008 12:16 PM
Need to know how a glass slide works in a digital indicator? How does it read to be able to give accuracy of .001mm? How does it know where it's at on shaft and how does it see where it's at?
Re: Digital indicator (drop gage) works
01/10/2008 12:23 PM
Your question is a little vague, but the types of glass slides I've seen and used for measurement purposes, are diffraction gratings from which moire fringes can be used to interpolate between the fringe widths, allowing much higher resolutions to be obtained.
1 micron is easy some can be interpolated to 0.1 micron and better!!
John.
01/11/2008 10:21 AM
I'll take a stab at this slightly general question. Only because I'm boning for a 'good answer' mark
A glass scale such as is used in DRO's and the likes is pretty simple. An extremely precise lay out of incremental marks is laid out on and embedded between 2 panes of glass. Some of these incremental, embedded scales are conductive (older) and some are simply light absorbing (a dark mark).
The scale is fixed and a reader or encoder(?) passes over the scale. The reader is oriented to a zero datum and counts marks as it moves. Some (as I recall) use light or laser technology (photodiode?) and others read by use of an electro magnetic means as it passes over the conductive marks.
The above is for a linear device though a rotary would be most similar in it's workings.
This is the general workings as my memory serves to a rather general question. Hope it helps.
cr3
I suspect I should get a 'B' if this is schoolwork.
