Previous in Forum: Manufact7uring   Next in Forum: Is the process of Blast furnace Iron making dying?
Manufacturing
01/11/2008 2:35 PM
What is the formula for the total depth to feed the cutter in from outside of shaft to bottom of keyseat
Re: Manufacturing
01/11/2008 2:40 PM
Machinery Handbook, pg.....
Re: Manufacturing
01/16/2008 12:30 AM
Are you doing a few or high production? If it is only a few on a manual mill you don't need a formula. If you are cutting a 1/4" keyway with and end mill, just mill a flat on the shaft until it is square. Then drop down 1/2 the total depth of the key plus a couple of thousandths. Takes about 30 seconds.
Peace be upon you.
Re: Manufacturing
11/22/2019 11:44 PM
CR4 Admin: Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the Site FAQ about advertising.
Re: Manufacturing
11/23/2019 2:14 AM
This is not ordinarily done by a formula; rather, it is done by looking it up in a table of standardized dimensions.
Many shaft keys, if square, are about 1/4 x shaft diameter, with keyway depth being 1/8 x shaft diameter. But this may be rounded off to some whole number of millimeters or inch fractions, for example. Also there are shallow keys versus square keys, and other variations.
Keyway depths are typically measured from the outer surface of the shaft.
Register to Reply 4 comments
Skelley (1); TexasCharley (1); Tornado (1); Willie B (1)
