Previous in Forum: Polystyrene Foam Coating   Next in Forum: Welding Of P91 to SS316 / SS304 Material
Color for SAN (Styrene Acrylonitrile)
01/14/2008 12:47 PM
I am using a transparent SAN (Styrene Acrylonitrile) and now I have to change the transparency of this material and make It translucent grey. Is possible to add color to the original material? (I don't want a solid color, translucent only).
Thanks for your help.
Re: Color for SAN (Styrene Acrylonitrile)
01/15/2008 2:40 PM
I am familiar with two ways this is done.
In most cases the transparent material is changes to translucent by surface texture. If your material is rolled there are rough surfaces applied to the rollers that do this. Think if a clear plastic shower curtain that has translucent fishies on it. The rollers are etched similar to printing rollers. Thicker materials can be chemically etched like HF acid on glass.
A different method is to add a different material that is also clear but has a different refractive index. The combination diffuses light resulting in translucency.
You could add gray dirt.
Give more details of the method of mfg or intent, end product, you will get better answers.
Reply to Forum Thread
