i need a compressor that can deliver 100psi @15scfm single phase with the lowest watts . this is to drive a inter face devices {air driven hyd pump ???
A general rule states it takes 1 HP to pump 4 SCFM to 100 PSI which means you need almost 4 HP to get the volume you want. Single phase motors this size are not low wattage.
