Hello All,
We currently operate 6 BIRD screen bowl centrifuges for the dewatering of potash slurry from a crystallized pond product (solution mine). The process involves dredging the material from the pond and pumping to pond storage tanks, it is then pumped to the plant to a another storage tank where the slurry is pumped to a cyclone and then to the screen bowl centrifuge. The screen bowl centrifuge solid product is then dried in a rotary dryer and then processed. The % solids and particle size of the feed stream can vary depending the outside temperature, location of the dredged product, and the concentration of the KCl.
We are planning an expansion (adding two more centrifuges and another dryer) to increase capacity and I was wondering if anyone has had any experience with pusher centrifuges and screen bowl centrifuges. There are a few advantages of a pusher over a screen bowl but I am concerned with the amount of maintenance that a pusher may need. Does anyone have operational/maintenance experience with this type of machine and if so what is your opinion?
Thanks,
SPOD
