Previous in Forum: What About the R.O.U.S's !?   Next in Forum: Motional Electromagnetic Generator ( MEG )
8 comments
Number Theory & Mysticism Part 1
01/16/2008 8:04 PM
This series was requested in another discussion. -S
This chapter explores relationships in numbers. Some are interesting, but appear to have no practical value. Who am I to say that nobody else will find practical use for what I see as useless? Let the reader decide. Some of the material is historical in nature. Make of it what you will.
Certain ancient Greeks looked for patterns in numbers. One remarked that "all is number." They had only integers at the time, which they used in making fractions. Odd numbers were considered male, and even numbers female. Triangular patterns could be made with dots numbering 3,6,10, and so on. The one with 10 dots was called the holy tetractys. Square patterns could also be made using 4,9,16, etc. The next higher one could be made by adding an L-shaped border called a gnomon (carpenter's rule). It was discovered that each odd number was the gnomon of a square number. For example, 7 dots are added to a square of 3 by 3 to make a square of 4 by 4. The number 1 was identified with reason; two with opinion (a person with two opinions wavers). The number 4 stood for justice, steadfast and square; five for marriage , the union of the first even with the first true odd number. Seven stood for the maiden goddess Athene 'because seven alone within the decade has neither factors nor product.' Today the number seven is considered lucky, and the number 13 unlucky. Could the latter be because Christ + 12 Apostles = 13?
It is worth noting that, in geometry, the number 1 came to be identified with the point, 2 with the line, 3 with the surface, and 4 with the solid. Today, with our dimension concept, we identify 1 with the line, 2 with the surface, and 3 with the solid. Which is better? One of the 5 regular polyhedrons, the dodecahedron, is roughly spherical and represented the universe.
For some numbers such as 6 and 28, the sum of the factors equals the number (6 = 1 + 2 + 3 and 6 = 1 * 2 * 3). These the Greeks called 'perfect' numbers. Many have tried to find a rule for finding all these numbers. Can you prove or disprove that no odd number has this property? Such endeavors are the essence of the theory of numbers.
Part 2 will be Prime Numbers.
S
Re: Number Theory & Mysticism Part 1
01/17/2008 5:23 AM
number theory, this seems to let me back to college class.
mark it
Good Answers: 143
01/17/2008 7:58 AM
Personally, I prefer 11 or the White Album.
01/17/2008 7:51 PM
Texans hang on to our system of units and oppose the metric system because if Jesus had endorsed the metric system he would have had 10 disciples rather than 12....
Good Answers: 143
01/18/2008 7:35 AM
Unless He lived in west Texas, in which case He would have had 11 so they could play football.
01/18/2008 12:16 AM
Try googling Gematria.
Gematria The Mathematics of the Torah
It is the basis for most number mystical systems. This is a basic outline of the values. The uses are much more diverse.
http://www.inner.org/gematria/gemfull.php
2 bits from
Brad
01/18/2008 12:20 AM
extremely interesting when will you post more ?
many fraternities whose members are interested in study of the seven liberal arts and sciences would appreciate recieving more either directly from this website or as part of the lectures which form a part of their regular meetings. how may permission to reprint this for the benefit of those society's whose members are unable to acces the internet?
thank you,
'da ber 3-4-5
'da ber
01/18/2008 3:18 PM
Hi, Guest,
Thanks! You should check with the lead editor, Chris Leonard, to see if CR4 has any problems with it being copied. I have none, but don't credit me, I don't know where I got it. I will post part 2 now.
S
01/18/2008 4:10 PM
Number theory crops up in the oddest places. For example, there was a requirement for a pair of counter-rotating carriers to have equal moments of inertia when loaded with different numbers of identical loads - the loads needed to be moved in the same plane and the system needed to be compact. Do I hear cries of "Pythagorean numbers"? But they needed more loads to be moved and with closer spacings than that would have allowed.
Register to Reply 8 comments
Anonymous Poster (2); cnpower (1); StandardsGuy (1); Steve S. (1); TVP45 (2); U V (1)
