Previous in Forum: know about valve   Next in Forum: bevel gear
pressure queary
01/17/2008 11:35 PM
is it possible that 0 pressure possible, if 1 kgf per square centimeter in vaccum , what is absolute pressure.
learning never ends
Re: pressure queary
01/18/2008 3:28 AM
Re: pressure queary
01/18/2008 3:55 AM
Take a cardboard tube from a toilet paper roll.
What is the differential pressure between the two ends? Zero.
In a perfect vacuum there will be an absolute pressure of zero..but this is harder to achieve, however it is easy to get a reasonably good vacuum where the pressure will be only a few mm of Hg. (e.g a peristaltic pump will produce this type of 'soft' vacuum)
Register to Reply 2 comments
You might be interested in: Pressure Gauges, Pressure Sensors, Pressure Switches
