Previous in Forum: i want to know what is mechanical engineering   Next in Forum: pressure queary
know about valve
01/17/2008 11:32 PM
what types of vale is used in low flow rate , where pressure loss is not matter,
learning never ends
Good Answers: 101
Re: know about valve
01/17/2008 11:40 PM
"what types of vale is used in low flow rate , where pressure loss is not matter"
For what purpose? Different valves are used for different purposes, so without details, your question cannot be answered.
01/17/2008 11:50 PM
what are the essential detail ur required for selecting the valves, describe it?
Good Answers: 101
01/18/2008 12:10 AM
Function, flow, pressure, fluid type, essentially the same details as selecting a pipe.
01/18/2008 5:06 AM
All pipes, and fittings including valves, present a loss of pressure to flow, as the materials they are made from present friction to the flow.
<...where pressure loss is not matter...>
Pressure drop is a primary consideration in the design of any piping system, as it enables the system to be correctly sized on the balance between investment and operating cost.
01/18/2008 11:10 AM
VALVE?
NEEDLE type!
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
01/22/2008 4:17 AM
If your after good control (and not worried about pressure drop) use a small one!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Register to Reply 6 comments
Anonymous Poster (1); Beej50 (1); DVader1000 (2); MUKULMAHANT (1); PWSlack (1)
