Previous in Forum: metals   Next in Forum: how profitable the synthesis of the ethanol is starting from the ethylene?
9 comments
water
01/18/2008 6:53 PM
Is calcium naturally in water?
Good Answers: 918
Re: water
01/18/2008 6:57 PM
That depends on the source of the water.
The term "Hard" water (not to be confused with heavy water) contains calcium and magnesium. Water softeners are used to remove these minerals. Usually well water in most states needs to be treated to remove these minerals, but some wells have very low mineral amounts.
Purified water removes these and distilled water even more so.
Re: water
01/19/2008 4:16 AM
If the local rock is chalk, limestone or anyother variant of calcium carbonate .... the answer is yes.
Good Answers: 266
Re: water
01/19/2008 9:09 AM
Yes The level of which depend upon the geology of the area it comes from and how its collected. Areas high in limestone would have high levels of calcium in the well water. Water collected from the rain falling in the same area would have trace amounts. Calcium is one the dissolved mineral found in the water.
Re: water
01/20/2008 8:50 AM
4 out of 4 of the first responders say......YES. Though it can be unnaturally found in water too.
You can fortify and flavor your bottled water by crushing and adding products such as Tums with calcium.
Re: water
01/20/2008 1:07 PM
Absolutely. That's one of the things a water softner removes from water to make it "soft". It replaces the calcium ion's with sodium ions. The sodium components won't precipitate from the water, and eliminates the formation of a ring around the tub!
Re: water
01/20/2008 3:41 PM
I hate those softeners. I always feel like I still need to rinse.
Re: water
01/20/2008 5:34 PM
More importantly, try not to drink to much of it. Softened water can have too much sodium in it for some people (especially those with hypertension). In that case, you're definitely better off washing with it, and not drinking it. On the otherhand, in Bangladesh, they'd probably love to just have any kind of water to drink that did not contain unusually high levels of arsenic.
Re: water
01/21/2008 3:53 AM
Calcium is found to varying extents in all surface and spring waters, including seawater.
Calcium is added to RO permeate and evaporator distillate produced from water-makers on ships so as to add some taste and reduce the prospect of corrosion in the downstream pipework.
Good Answers: 101
Re: water
01/22/2008 10:19 PM
Yes for hard, no for soft.
Anonymous Hero (1); bonzoboy (2); DVader1000 (1); ozzb (1); PWSlack (1); TexasCharley (2); user-deleted-1105 (1)
