sir ,
we have a (100mw) axial flow siemens make steam turbine.now there is drop wise condensate leakage from Lp stage partig off line flange joint.It is too difficult to locate that point in turbine running condition as there is high temperature.Is there any process available for locate that leakage point in turbine running condition and also the possible points where leakage can be occured.
