Previous in Forum: Welding   Next in Forum: Steam Turbine
Failure
01/20/2008 4:01 PM
I am unable to mwork out one the assignment home work assigned to me ...plzz try to help me out..below i am placing the question
There is a 42" OD X 140" long(indoor) catalytic convertor/muffler made of 3/16" thick A36steel.The exhaust temperature inside them is 1100 deg fahreneit.They last,typically,about 5-7 years.One external factor was changed and 4 units failed after one month.Speculate why.note:The A of A36 indicates ASTM designation.
This discussion was "closed" on 01/20/2008 7:06 PM. No new comments are allowed.
Message from admins:
Homework
Re: Failure
01/20/2008 4:06 PM
We keep getting these ludicously vague questions on this forum....
'One extrenal factor' could mean anything from design, to supplier of the material or any one of the process involved in manufacture.
The question is either
a) Extremely clever insofar as it will make you consider all these factors (which is what I suggest you do) or it is..
b) Extremely stupid as it is so vague.
My personal view is that it is b).... I suggest however you should treat it as a)
Re: Failure
01/20/2008 4:09 PM
How does our helping you with homework, help you to be a competent engineer?
Good Answers: 183
Re: Failure
01/20/2008 4:34 PM
How much is 2x ?
How much is square root from v ?
How far is New York from ?
How heavy is a square meter ?
How light is a cubic foot ?
If you can give me an answer to those questions then i will give you an answer to yours.
Good Answers: 143
Re: Failure
01/20/2008 4:37 PM
I'll answer your question with 3 questions:
Why did you use 3/16" A36 steel for a catalytic converter?
What fuel was being burned?
Did you ever own a '58 Chevy?
Re: Failure
01/20/2008 4:50 PM
Considering few parameters just give me some generalizes answer where i can look onto...I mean like what are the failures possible in the catalytic convertor at 1100 deg fahre which is made of A36 steel...
Homework
nick name (1); shashank.beerla (1); Steve S. (1); TVP45 (1); user-deleted-1105 (1)
