Previous in Forum: va/ ve   Next in Forum: Flow Rate of Air??
passive component
01/23/2008 2:33 AM
I´m looking for an definition of an "passive component" in maintenance manner.
Lennart Gradén, lennart.graden@vattenfall.com
Sweden
Engineering Fields - Mechanical Engineering - By Degree Engineering Fields - Manufacturing Engineering - By Profession Popular Science - Weaponology - By Interest United States - Member - Member Since My Inception
Re: passive component
01/23/2008 6:36 AM
Accoding to Wikipedia...
Passivity is a property of engineering systems, most commonly used in electronic engineering and control systems. A passive component, depending on field, may either refer to a component that consumes (but does not produce) energy, or to a component that is incapable of power gain. A component that is not passive is called an active component. An electronic circuit consisting entirely of passive components is called a passive circuit (and has the same properties as a passive component).
Light travels faster than sound. That's why some people appear bright until you hear them speak.
01/23/2008 7:01 AM
Thank you for the answer, but I was thinking of mechanical parts in a plant.
01/24/2008 3:14 AM
passive component in plant system??
pipe, bypass, directional control valve for lubricating system,
there is so many passive parts on lubricating system i think
i am sorry if this not help
Register to Reply 4 comments
All About M.E. (1); Anonymous Poster (1); Lennart Gradén (1); megAnthos (1)
