Previous in Forum: Saltwater fuel???   Next in Forum: How to Paint Over Aluminum?
R-23 Recovery From H2 and Contaminated With H2O
01/23/2008 7:38 AM
I have a stream consisting of about 5 volume % R-23 in hydrogen (its roughly 60 wt% R-23). The stream has water in it with a dewpoint of about 0C and contains CO2 @ about 100 ppm. The stream contains about 1-2 kg/hr R-23. What would be the most cost effective way to recover usable R-23 (need water dewpoint of < -110C and CO2 < ~ 1 PPM)? When operating only a few hours/yr this is a manageable problem, but not at hundreds of hours/yr.
All generalizations are false, including this one.
Re: R-23 Recovery From H2 and Contaminated With H2O
01/24/2008 2:37 AM
Dear colleague,
The appropriate molecular sieve packed in a column will do the job.
Sincerely,
Jacob Scheinert
01/24/2008 7:46 AM
Thank you. Will molecular sieve separate all three impurities? (H2, water, CO2?). I didn't think it would do anything for the H2 and believe the CO2 capacity is limited.
Is there a better way to get rid of relatively large amounts of CO2 (I had a typo in the original posting, it is closer to 1000-2000 ppm Vs 100 ppm stated)
Good Answers: 150
01/24/2008 9:17 AM
A dessicant dryer will do wonders for the water, so we can effectively deal with the water fairly easily.
R-23 is much denser than air whereas hydrogen isn't. You could probably use some kind of hydrocyclone to separate the two but it won't do much for the CO2. But an easier way to deal with that (and it would work for the CO2 as well) is a molecular seive as was stated previously. R-23 molecules are pretty big. CO2, not so much. H2 is even smaller and to be honest with hydrogen, the trick is usually to keep it IN, not out. It is so small it will seep through steel itself (slowly granted). so you could use a series of molecular sieves to sort the dry mixed stream into H2, CO2, and R-23.
Another way to skin the cat would be to refrigerate and liquefy them. H2 won't liquefy until you get it pretty dang cold. the boiling point at 1 bar is something like -82C for R23, CO2's boiling point is -78.5C, H2's is something like -259C, so that is another way you could separate the streams.
Who is John Galt?
Good Answers: 150
01/24/2008 9:20 AM
BTW, this is a nice little site by Air Liquide for various industrial gases.
http://encyclopedia.airliquide.com/Encyclopedia.asp?LanguageID=11&CountryID=19&Formula=&GasID=36&UNNumber=&EquivGasID=26&PressionBox=&VolLiquideBox=&MasseLiquideBox=&VolGasBox=&MasseGasBox=&btnMSDS=0&MSDSLanguageBox=11&RD20=29&RD9=8&RD6=64&RD4=2&RD3=22&RD8=27&RD2=20&RD18=41&RD7=18&RD13=71&RD16=35&RD12=31&RD19=34&RD24=62&RD25=77&RD26=78&RD28=81&RD29=82
Who is John Galt?
Register to Reply 4 comments
jack4171 (1); Rorschach (2); Worksalot (1)
