Previous in Forum: What is partial admission & full admission in steam turbine?   Next in Forum: Turbine Design
What may be the effect if we run turbine in low load?
01/25/2008 8:14 PM
also what is the air gap between rotor & stator?
Re: What may be the effect if we run turbine in low load?
01/25/2008 9:52 PM
1) Low power output
2) clearance between rotor and stator in the generator.
01/26/2008 12:04 AM
At low load the steam to the turbine is throttled, this causes a drop in steam temp and consequently it effects the turbine shaft expansion, so like you pointed out there will be a narrowing of the gap between the rotor (turbine blades?) and nozzles (stator?), The turbine manufactures will have limits on positive and negative expansion. If you are refering to the alternator? then I think the H20 cooling kepts it stable, an electrician may help you there. If it is the alternator maybe you should post it in Electrical Engineering?
